what bar is out map sensor
  • #16
    i think what he has been trying to ask is, can it be converted from maf to map, because he heard that map was easier to tune with alky inj. but i have always thought its easier to tune with a maf isnt it?
    • #17
      depends on the tuner... i can tune the shit out of VE tables, but when it comes to MAF values it takes me a little longer...
      he is in a bit of a problem: has an automatic, which means he either needs a PCM that will control the tranny or wire up microswitches like 95sleepracheiva is doing, or convert to a manual trans. when there is a decision on which one of those three is made, then we can progress.
      • #18
        1991-1993 DOHC: MAP OBDI
        1994-1995 DOHC: MAF OBDI (1.5 as it is commonly refered too)
        1996-1997 DOHC: MAF & MAP (1bar) OBDII
        1 BAR= -14.5 to 0 vac
        2 BAR= -14.5 to +14.5 psi
        3 BAR= -14.5 to +29.0 psi
        all factory NA cars are going to have a 1bar map... on my turbo setup i have a 1996 engine harness and ECU.. the factory 1bar map maxes out and the ecu adjust fuel based upon MAF readings. So my map really only does anything for low rpms/idle under boost relies on the MAF for everything while in boost. Your stock ecu will not read anything beyond 0 vac from the MAP.. its not designed to read boost from the factory.
        Shane "RedZMonte"
        1992 Lumina Z34-VIRGIN (RIP)
        1992 L67 Lumina Z34 (SOLD)
        1990 Turbo Grand Prix (SOLD)
        • #19
          This thread is full of win!
          • #20
            we can only do so much....
