Starters V8/V6
  • Starters V8/V6
    I seem to remember someone once telling me that a V8 5.7L Starter will fit a 60DEG-V6 3.4DOHC.
    Can anyone confirm or deny this statement?
    I dont know what this means but "ASS HATS" is funny
    i have heard a 3100 starter will fit a 3.4 dohc.
      yeah the 3100 or even a 3800(longer i think) will fit. An LT1 starter is standard measure so i wouldn't try.....
      Lorenzo
        my starter on my Z34 is off a 02 grand am GT with the 3400. It bolted right on with no problem, actually since its the "mini" starter it went on much easier than the stock behemoth came off
        68 El camino 454 speed muncie 3.90 posi 12 bolt,
        80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
        60 Impala 2 door hardtop L79-327 T56 4.11 posi.
        83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
        91 Z34 now has a hm284. and belly pan in the works
          yep yep. i have been meaning to upgrade to one myself. do you have an oil cooler latemodel wannabe? were you able to install the3400 starter w/out haveing to remove it?
            my car does have the water to oil cooler, I had to take off just the oil filter not the whole cooler assm. to remove the stock starter with a few choice words but I could have installed the mini starter with the oil filter still on. I think i took a pic of the 2 starters side by side but i can't find it, the size difference is amazing
              So the starter on a 3400 is smaller with higher output? Any pics would be great.
                Its a gear reduction starter, it has a set of planetary gears in it. It works great my car starts faster, it sounds better when cranking, not too much of an issue with these cars but heat soak doesn't effect it.
                Autozone charges $134.99 plus a $32 core but you can find one at junkyard for much less. I paid $17 at pick in pull, I'll pulled out of a wrecked grand am but apparently the wreck was bad enough to to screw up the starter but I used it as a core for a new one.
                I still haven't learned how post pics. but the autozone website shows the correct starter just use a 2002 grand am with 3400
                  Hmm, good to know!
                  Fiero gt 3.4 DOHC turbo forged bottom end MSII
                  94 Ranger 2.3 turbo t5 (DD)
                    yeah thanks latemodel. That is what I wanted to know. Sweet!
                      i have an AC Delco reman from an "01 Impala 3400". Paid 115 for it. I ordered that and one for a 96 3.4. They were both gear reduction, but the 3400 one was slightly smaller (lighter). The 3.4 one had a different number of teeth than the one i took off, so that was another reason i used the 3400 one.
                      91 GTP HM-284 GONE
                      96 Special Edition LQ1/4T60E GONE
                      98 Spawn of Satan (L67 Regal)
                      87 V10 SM-465/Mild 350
                      06 Cobalt SS/SC GONE
                        yeah running one too. works great.Has that late model GM starter sound
                        Lorenzo
                          yeah, i love that sound for some reason.
                          91 GTP HM-284 GONE
                            they sound like a quiet old mopar v8 starter. a little gear noise is good but the mopar one are excessive.
                              Well I also still like the classic GM sound but the starters are so much bigger and there is only so much room down there....
                              Lorenzo
