Starters V8/V6
  • #16
    when i replaced my starter, all-data said i had to remove all sorts of stuff and i only had to remove the oil filter and flywheel cover.
    i heard you dont need a shim for the newer style, so i didnt put the old one in and its working great. i did have a little trouble w/ the one i got (wouldnt turn over), but i got it replaced and no problems since.
    91 GTP HM-284 GONE
    96 Special Edition LQ1/4T60E GONE
    98 Spawn of Satan (L67 Regal)
    87 V10 SM-465/Mild 350
    06 Cobalt SS/SC GONE
    • #17
      I only had to remove the oil filter and one bolt on the dogbone and have my buddy rock the motor one way, can't remember if we had pull it or push it but it take much. That was only to remove the huge ass stock starter I didn't need to rock the when I put the mini starter on. As for shiming the starter just put and if it works rights and the gear noise is not excesive don't worry, I just threw mine on and it worked fine
      68 El camino 454 speed muncie 3.90 posi 12 bolt,
      80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
      60 Impala 2 door hardtop L79-327 T56 4.11 posi.
      83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
      91 Z34 now has a hm284. and belly pan in the works
      • #18
        In late 02 gm redesigned the starter again for the 3400. a 2.2L pushrod motor also uses this new starter. casting number on the even smaller lat 02 starter is 9000901
        • #19
          These mini starters on the late 90s cars are awesome. They're 7 lbs versus the stock DOHC starter's 13.4 lbs!! They're easier to install, sound cooler, and give more room for working on things like the coil packs (if in the stock location) and the oil filter / oil cooler.
          It's a very good upgrade or replacement, especially if you can find them in the junkyard for $20 like I did.
          I'm interested in checking out the '02+ starters, I'll have to keep an eye out for them at the junkyard. Any idea how much they weigh?
          • #20
            So this has been dead for a while but has anyone tried an 02+ 60DEG V6 starter yet?
            I dont know what this means but "ASS HATS" is funny
            • #21
              I put the 3400 starter on my 3100 and loved it. I was a little worried about it being able to turn a LQ1 since it has more valves to push down. The LQ1 is simply takes more force to turn. But it starts up fine with the 3400 starter.
              Heres a video, starts right up with the 3400 starter.
              Some pics
              And Im pretty sure all 60* motors 97+ use the smaller starter.
