lx5 tb adaptor
  • lx5 tb adaptor
    are these goin to be made again as their not listed on the store anymore
    bump for an answer
      someday.
        someday.
        Ben is hoping I'll make them before Christmas
        Actually we just got finished making 2400 cabinet handles, that took up the mill for a few weeks, so I have one more job to finish up and they are next.
        Sorry for the delay on these guys, but there will be an entire 12' bar used up on them this time, so that SHOULD last a little while.
          Ben, can you see if a 96 TDC TB bolts up to these? It looks like it would, similar design and all. Just the vacuum nipples are bigger.. Close to same diameter too .
            im sure u guys r tired of me askin but is there a eta on these? just wanna know cuz if its gonna be more than a week or to ill run a 3400 uim for a while. sorry again i know im a pain. thanx guys
              you must die you pain!!!
              LOL, J/K
              I have the Fiero brake adapter material right now, cutting them tomorrow. Will take a few days, then the TB adapters will be back
                any updates?
                  John should be getting close to making them.
                  I'm still curious about the 96+ 3.4 DOHC TB bolting to these...
                    I have a complete 96 DOHC top end, so the next time I am down at Ben's, or he is up here if he grabs an LX5 UIM I could pull my TB off the arm and check.
                      You'll need the LX5 ADAPTER to check. It won't bolt up to the 3500 plenum as is, but looks like it's close to the same as the Olds TB.. I forget the diameter of the 3.4 DOHC TB but I think it's close to 65mm.
                        IIRC it's 65mm stock and the "bored" RSM was claiming to be 72mm, but actually measured 69mm, which was as big as you could bore one safely before going into the coolant passage.
                          Well, we aren't milling naything right now, the machine is being moved to the new shop tomorrow
                          This also puts a hold on the l-body headers.
                            crap mo stank.
                              any updates?
