Diamond forged 3400 pistons now available
  • #16
    So what would the recomended cr for a 3.4 with 3500 heads running on 91 octane ?
    • #17
      Its about 5hp difference from 10.8:1 and 11.5:1 on your setup according to dynomation. I don't know that 5 crank hp would be enough to make me want to keep stock cast pistons over a forged of these quality.
      cool thanks Ben.
      yeah i would definitely be using these over the old rwd pistons.
      these will be this years winter time mod.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
      • #18
        Ben has a client that is running 12.6:1 (is that right Ben?), we've both had several that are running 11.5:1.
        • #19
          12.4:1 is what Eric is running on premium. I would go with the 11.5:1 (10.8:1 with 3500 heads). 91 octane could be midgrade or premium, depending on your elevation. Either way, 10.8:1 should be no problem.
          • #20
            wouldnt that hi of compression ratios be kind of radical on the street? just thinking in v8 terms i guess but 11.5 and up cr just seem hi for pump gas in a daily driver, could be wrong, first time on this build with a 3.4 rwd and interested in the 3500 swap.
            '69 F-100
            '76 Chevette Scooter
            '85 K5 1/2 ton
            '86 S-10
            '87 K5 1 ton
            • #21
              With aluminum heads, 11.5:1 is pump gas. I built a 12.4:1 that runs on pump gas for that matter.
              • #22
                I ran 10.4:1 last year with 89 octane E-10 and had no problems.
                • #23
                  LS1 runs 11:1 stock don't they? There's your high compression V8 streetable comparison right there.
                  • #24
                    I don't think they are quite that high out-of-the-box; just checked and the 350HP crate motor is 10.25:1. Just had a friend stuff a LS3 in his 2001 F-body and it was spec'd at 10.7:1 on the compression.
                    Matt
                    • #25
                      Might have been LS6 or something. I recall one of them being that high. Oh well maybe not, but 10.7 is up there.
                      • #26
                        Well seeing the "typical" high compression iron head Gen1 V8 can run about 10.5-11:1 and aluminum head can generally run a point higher, even going by what's been done on a regular basis 11.5:1 is really not THAT high, specially when you are talking about super efficient fast burn chambers
                        • #27
                          the highest LS motor compression id the LS7 at 11.1.1. then theres the c5r race car with the highest
                          LS1: A319 T5, 107#
                          Displacement = 5.7 L. / 346 CID
                          Bore x Stroke = 99mm x 92mm / 3.90" x 3.62"
                          Compression Ratio = 10.1:1
                          Horsepower = 345/350 HP @ 5,200 RPM
                          Torque = 350/375 #-Ft. @ 4,400 RPM
                          Redline = 6,000 RPM
                          Fuel Cut OFF = 6,200 RPM
                          All engine Generic Data:
                          Firing Order = 1-8-7-2-6-5-4-3
                          Spark Plug Type = 41-931
                          Spark Plug Gap = 1.524mm / 0.06"
                          Oil Type = Mobil 1 (E) 5W-30 Synthetic or Equivalent
                          Oil Capacity = 6.5 Quarts / 5.7 L. (With oil filter change)
                          Oil Pressure (Minimum - Hot):
                          1,000 RPM = 41 kPa / 6 psig
                          2,000 RPM = 124 kPa / 18 psig
                          4,000 RPM = 165 KPa / 24 psig
                          Length = 519mm / 20.43"
                          Width = 460mm / 18.11"
                          Cylinder Bank Offset = 24.10 mm / 0.949"
                          Bank Angle = 45 degrees
                          Deck Height = 234.7 mm /
                          LS6:
                          Compression Ratio = 10.5:1
                          Horsepower = 385/405 HP @ 6,000 RPM
                          Torque = 385/400 #-Ft. @ 4,800 RPM
                          RedLine = 6,500 RPM
                          Fuel Cut OFF = 6,600 RPM
                          C5R: A356 T7
                          Displacement = 7.0 L. 427 CID
                          Bore x Stroke = 4.160" x
                          Compression Ratio = 12.5:1
                          Horsepower = 650 @
                          Torque = 525 @
                          RedLine = 7,500 RPM
                          LS2:
                          Displacement =
                          Bore x Stroke =
                          Compression Ratio =10.9:1
                          Horsepower =
                          Torque =
                          RedLine =
                          Fuel Cut OFF =
                          LS7:
                          Displacement = 7.0 L. / 427 CID
                          Bore x Stroke =
                          Compression Ratio = 11.1:1
                          Horsepower = 500 HP @ 6,200 RPM
                          Torque = 475 #-Ft. @ 4,800 RPM
                          RedLine = 7,000 RPM
                          Fuel Cut OFF = 7,100 RPM
                          Dry Sump
                          99 Grand Am GT
                          • #28
                            that was informative... and when it mentions bank angle and says 45, it does mean each bank is 45* from the centerline, yes?
                            • #29
                              Yes. 90* inclusive (or included) would be the common term used when talking about bank angle - side to side.
                              • #30
                                makes more sense, i couldn't imagine why anybody would make a 45* V8...
