Idea.. maybe?
  • #16
    I think Dave streched a stock chain out in 1500 miles...
    • #17
      Pretty sure Eric stretched his in 1300 or less. Its the higher compression mostly, which DOHC owners can't really touch:P I wish we could, but 11:1 is not easy to achieve.
      • #18
        Ok, I am probably wrong. I thought it was Dave :P
        • #19
          318 seals working good for me, 50+k miles. Just to add input.
          Brian
          3400 SFI V6, 4T60e
          • #20
            closer to 700 miles...
            it wasn't the seals fault, it was the spring seat.
            • #21
              Pretty sure Eric stretched his in 1300 or less. Its the higher compression mostly.
              For some reason, that doesn't make any sense to me. Why would high compression cause the chain to stretch? The cam doesn't turn the crank.
              Andy
              fastest 1/8: 10.19@ 67.17
              fastest 1/4: 16.16@ 82.70
              • #22
                It is not a constant journey for the crank gear to spin around. 6 evenly spaced combustion events are the source of energy and the crank sprocket is attached to the cam sprocket, which is on a different set of pressure variables for which the crank must act against. The bigger the cam/springs and the more powerful the combustion, the more abust the chain takes.
                Hard launches and faster shifts take their toll on the chain. Driving style is a large factor to longevity at any performance level.
                • #23
                  How about when that guy John3400 had the detonation? It sheared the cam pin, and spun the cam gear.
                  • #24
                    O.O That's insane!
                    • #25
                      Ohhh yeeaahh. Forgot about the engine changing speeds suddenly. I can see that CR would play a role since more will cause more power, but just the same, you can add headers or bump timing. Increasing CR.......hmmmmm, I'm thinking about HP gain, not difference in pressure. I see your point Ben. A little HP needs a lot more pressure during combustion. Therefore, a more abrupt speed up and slow down pulses.
                      Andy
