Forum Cookie Problems
  • #16
    Working good on FF now.
    • #17
      Just ran into it again. I will clear cache and cookies and see what happens.
      • #18
        I just changed a setting for caching of threads, so we'll see if that changes anything.... I am still getting the errors, unless I try via a proxy (host recommendation). If this setting changes things, the site may seem a little slower.
        • #19
          I've tried another thing recommended by the host, so hopefully it clears this issue up.
          • #20
            nope. ill clear everything and try some more
            • #21
              BAck to the way it was. Worked on FF, now Explorerr is doing it again.
              • #22
                testing
                • #23
                  testing
                  1,2,3
                  • #24
                    seems good right now
                    • #25
                      Still bites. I'll sit back and shut up, till someone E Mails me and tells me how to fix. Cleared cache and cookies. 4 times. Can't post, can't log out, or in, and says my token has expired.....wtf?
                      • #26
                        Can you get a screenshot when you get a token error? That would help me figure out what is wrong. I haven't had any further issues since Sat afternoon.
                        • #27
                          Fresh OS install on the 2nd lappy, still acting weird. Couldn't post at all, and new posts still not showing. When using the "quick quote" it kind of worked, but if I used the "quote button" it got stuck on a blank page inside the reply box.
                          • #28
                            Well, I don't think its browser specific, as I'm using Firefox at home and IE7 at work. The problem didn't exist (as far as I know) last Friday when I was at work, so everything appeared fine there. And today, it was still acting just fine.
                            • #29
                              IE7 at work and home, no problems in a few days...
                              • #30
                                I think I fixed me. Deleted AOL and IE 8. Full reinstall. Let's see if this works.
                                At least I'm on the right day. I'll save further evaluation for later.....
