A new page entry has been added:
[drupal=134]Throttle Body Spacer[/drupal]
Port injection
The TB spacer is meant to keep the throttlebody cooler, by seperating it from the manifold using a phenolic material instead of metal. The misconception is that by adding space behind the TB, you are going to get more torque.
The lowered temperature is fine, and is worthwhile (see TB coolant bypass), but the cost of a spacer and the remaining intake manifold temperature doesn't do a whole lot on its own. The performance myth with this device is that it allows more air in, or that it lengthens the runners, or anything else along these lines.
