3400 heads
  • 3400 heads
    hey good peeps , got a question ... does anyone know where ican get sum good performance heads? i have an 3400 from an '01 grandam in my olds acheiva the swap went well...help would be appreciated..planon putting a remote mount turbo set up, help and advise would be helpful...thx..
    3500 top end swap would be suggested by most of us. If that isn't enough, then P&P the 3500 stuff before it goes on.
      install a turbo specific cam
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
        www.60degreev6.com/store if you want flow bench proven performance heads.
        02 GTP - 90* > Failboat
        www.blackbombshell95.com
          I am having a set of 3400 heads cut for the 1.8/1.52 valves for boosted applications. I will then post flow numbers for the heads and then with the ported manifolds once I am done.
          I am very impressed with the ported 3500 top end for its ability to flow at the lifts that matter most. You have to compare the entire system, not just the heads. I will have all of the numbers asap, as well as an article explaining the key differences between the setups.
          Ported 3500 parts will be on the store soon 3500 top end swap parts to work on the 3400 engine will be on the store soon as well.
          Are you talking about the STS remote mount turbo?
            milzy motorsports has really good motor upgrades for the 3400 u should try there
              But before you go to MMS, Rob a Bank.....you r gonna need the money!!
                what are the flow numbers for the stock 3500 heads... i hear they out flow milzy stage 2 heads... LOL owned by gm equipment.. lol
