Custom pushrods on hybrids?
  • Custom pushrods on hybrids?
    How important is it to put custom pushrods in. I have a 3400 block with flat tappet cam and 3400 heads. I put in the 3.1 pushrods and haven't seen a problem with them. In fact i took them to my engine builder and he said they were okay to run. How much hp am i losing by using these if any?
    You should be alright. Are you using 3400 rockers or adjustable ones?
      I am using the 3400 rocker.
        Well thats fine the geometry will be stock like a 3400. But you should at least verify your preload with a dial indicator. Should be between .020 and .060
          i thought scott said your car was running, wouldn't u of asked this before hand
          btw i like what i've seen
          a checker is only $25 i needed custom ones for mine
            i needed custom ones when i switched over to a 3100 block and still used a flat tappet cam
            I Like V660s
            Does Chevy make beer
            ~Jayme~
