tb bypass mod and 62 mm tb
  • tb bypass mod and 62 mm tb
    i know this has been discussed before but i want to get a 62mm tb for my 3100 but in april i plan to change to 3400 P&P intake manifolds well im just wondering if there are any coolant lines on the 62mm ones or if i have to do the bypass mod. im pretty sure that they arent form looking at pictures but does anybody know what size bend i need for the byapss mod?
    1996 Monte Carlo LS 3100 engine, 1/4 16.131 *RIP
    88 cuttlass supreme 2.8L coupe
    90 dodge daytona 3.0 v6
    The 62mm unit from FDP and APOC doesn't have the coolant lines. As far as the bend you need for the bypass, I want to say its a 90º bend. I know that for around $10 you can actually get a kit directly from GM to do the bypass.
      Or you can get a piece of hose from the parts store.
      Or you can get a 94-95 Beretta 3100 metal line as they don't have connections for a heated TB.
      As far as your other mods go....I'm am still not sold on the 3400 top end swap or bigger TBs. For one, I haven't seen a dyno chart for either mods. Plus, the neck of the upper intake manifold on a 3400 measures 58 mm....so how is anything over that going to perform better.
      You should either get the entire 3400 or get a set of headers......which a few people are working on getting made....they make 18 hp on 99+ 3400 N-Bodys.
      -1996 Beretta
      3400 SFI / 4T60-E
      -1991 Grand Prix SE
      3.4L DOHC / HM-284
        I agree with the 3400 top end swap AND larger TB. The only thing I accomplished with the 3400 top end was fucking up a set of lifters and being without a car for 2 more days while I tried to figure out exactly what happened. Unless the engine really NEEDS more air, just stick with what you have.
          Yeah, its a 90* bend. I just went to a parts store and looked at all the different bends they had and picked the one I needed. I had to cut some off to make it work. I think it 5/8" hose.
          Robby Whitesell
          2006 Pontiac G6 GT
          1985 Toyota Pickup DLX
            so uits shaped as a u then and goes form one opening to the other on the coolant pipe
              Yeah, when you take the existing two hoses off the TB, you'll see two exposed coolant pipes, simply connect them with the bend. Its a short U-shaped, not a full U
              Robby Whitesell
              2006 Pontiac G6 GT
