Discussion: GM Recommended Crankshaft mods
  • #16
    From what I read on a couple Olds and Buick sites, they say the lead time is 10 weeks, but some have waited 21 weeks to 10 months for a crank.
    • #17
      I belive the 3.3L turned into the 3.8L which isnt a 60 degree v6. I bretty sure it was a 90 degree just like the current 3.8. The bottom ends are differend and can hold more power?
      2002 Pontiac GrandAm GT1
      3400 v6
      TOG headers
      RSM 62MM T-body
      FFP underdrive pulley
      GRANATELLI MAF
      Ported upper intake
      MSD DIS 4 ignition box
      MSD Wires and coils (pending)
      Venom high flow fuel pump (pending)
      • #18
        I found a company that makes billet cranks and has some raw ones on the shelf for the 60 deg v6. He ground mine to the stroke I wanted and shipped it out and I had it in less than 2 weeks. His name is Doug at crankshaft specialist. 901-452-6663 they are located in memphis tenn.
        95 Beretta Z-26
        • #19
          Just because it says a 3.3L doesn't mean its the production 3.3L. If you look at the crank info, its a stroker crank, therefore upping the displacement of a 2.8L or 3.1L engine.
          • #20
            How much was that crank? Not that I have any sort of cash for it but it would be nice to know.
            • #21
              It was almost $1800 without balancing.
              95 Beretta Z-26
