Aftermarket pushrods? 3400
  • Aftermarket pushrods? 3400
    I need information on pushrods themselves. I know nothing about them excect they move the rocker. Are there aftermarket ones that my future setup might possibly benefit from? Or custom lengths.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    RE: Aftermarket pushrods? 3400
    Crane cams makes custom pushrods. You must use one of there pushrod measuring guages you buy from them. Then you take those measurements and send it to them along with some other info. You can go to there website and they explain it all. http://www.cranecams.com/index.php?s...s&type=special
    98 camaro swapping in lz9 th400 setup
    LZ9 specs: (Subject to Change work in progress)
    4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
      any benefits of custom ones?
        If your looking for benefits from different lengths there are none other than IF the stock lengths are not optimum in terms of the geometery of the rocker location.
        You can get a specific length pushrod in many types of material. Stock style or lightweight. This is the only benefit from getting a custom set made up would be to have them made of chrom-moly or titanium or whatever for lighter weight.
        I've dealt with www.pushrods.net before for custom length 60v6's.
        Colin
          so i guess i'm fine with stock then
            new push rods are not suposed to flex under stress. but thats what i have heard
            Donesic Disurbance
            Grand Am 3400
              You are planning on getting a cam regrind right? Plus these heads are gonna get decked. Stock pushrods are not going to work as well as custom length. Please get the right pushrods for the application, its the best way to go and the only way I would go.
