3400 EMS
  • 3400 EMS
    I'm looking for an engine management system for my 3400 5 speed Beretta. Right now I have no Idea why, but my car will not run without cutting out really bad randomly. I want something that I can hook my laptop up to so I can watch everything and know what's going on, and also tune it better then what my 3100 ECM unit is tuned for. So if anyone can help me out I would be VERY thankful.
    1996 Beretta, 3400/5 speed, internet Tune, FFP UDP, Billet/poly mounts, ported intake manifolds, WAI, 2.5" mandrel exhaust, Borla ProXS, Intrax, KYB, poly front end kid, welded a-arms, strut, shock and sub-frame braces.
    haltech E6GM plugs right into the factory harness i belive
      Really depends what you want and how much you want to spend... Sure, the Haltech will work. But if you want to keep (or go back to) SFI, then look into units from F.A.S.T., Electromotive, and Perfect Power. Remember, the problem with alot of the standalone units is you have to start from scratch with the fuel and ignition curves. So it may take awhile to get it even running, let alone run well.
