Most a 3400 has been bored over?
  • Most a 3400 has been bored over?
    Anyone know what the most a 3400 can be bored over safely? For a N/A setup.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    1.50mm, or .060" over i think. it shoud be the same for all the 60* blocks exept fot bowties and prototypes.
      Sadly, boring a 3400 even 0.060" over brings it to just over 3400cc, since it initially starts out around 3350ish.
        oh that sucks. so .060 wouldn't be even close to being a 3.5
          this might be a stupid question but if 3100 and 3400 are the same block, to make a 3100 a 3400 it would have to be bored .120 over so technically couldnt a 3100 be bored .180 over of a 3400 can be bored .060 over???or am i just way off about that?
            But they're not quite the same block.
            60v6's original Jon M.
              They don't share the same block.
              Colin
                whats the diff???
                  The 3400 block is cast with larger cylinder bores.
                  '99 Z-28 - Weekend Driver
                  '84 X-11 - Time and Money Pit
                  Quote of the week:
                  Originally posted by Aaron
                    look at it this way, the 3100 block is like a 3.1l gen 2 block, and the 3400 is like a 3.4l f-body block.
                      ok thanks...this is a little off the subject but are the RWD and FWD blocks the same b/c....would a THM200 from a 80's firebird work on a gen3 3100???
                        the starter on the rwd blocks are on the right/ passanger side of the block, and the fwd blocks have the starter on the driver/front/left side of the block. One or both of the dowel pins in the back of the block for the transmission are in a different location too I beleave. not sure if all the thm200's got the aluminum torque converter covers but you would have to modify that for starter clearance too if you bolt it too a gen III block.
                        14.96@91.47 in the 1/4
                        9.63@74.36 in the 1/8th
                          i think mev from JBP bored 1 over to 3.8l. i remember seeing a post on v6z24.com a year ago saying that.
                          [SIGPIC]
                          12.268@117... 11's to come!
                            To just bore a 3400 to 3.8L, you'd need about 5.5mm overbore (.216in) giving you 3763cc (rounds to 3.8L).
                              They use their crank to get 3.8L, not the bore.
