MSD DIS 4 install
  • MSD DIS 4 install
    I'm just wondering if any one has installed one and had a no start, no spark problem. I'm still waiting on a tech from MSD to get back to me, so I thought I'd post a topic here. THanks for your help guys!
    Ps I'm running the car with the coil adapters in place and the jumper plug installed. and it runs grate!
    2002 Pontiac GrandAm GT1
    3400 v6
    TOG headers
    RSM 62MM T-body
    FFP underdrive pulley
    GRANATELLI MAF
    Ported upper intake
    MSD DIS 4 ignition box
    MSD Wires and coils (pending)
    Venom high flow fuel pump (pending)
    RE: MSD DIS 4 install
    is your purple wire grounded?
    3.4L camaro some goodies
      Ya the purple wire is grounded, the led on the side blinks after cranking is stoped. which seems weird! the thing I'm wondering the most is the wireing, even though it runs grate with the bypass plug! I'm thinking that the red wire goes to a different place!
      3400 v6
      TOG headers
      RSM 62MM T-body
      GRANATELLI MAF
      Ported upper intake
        a couple things to check here
        -the 2 step wire isnt grounded is it???
        -it is set on "waste spark" (should be) ???
          the waste spark wouldnt do that, and it would be fine to have the waste spark off anyway
          the blinking LED is a problem , IIRC that means that there is a problem with the DIS4
          im not sure how your ignition is set up so im not sure where the red wires should be going
            Yeah make sure the wiring is done properly. There are a few good charts around but when I did installed the setup last year it took a couple of days to get the wiring done right with the diagrams before it was running/running properly.
            http://www.v6z24.com/registry/ginobeats/
            http://www.v6z24.com/registry/ginobeats/2
              Yeah the diagram that msd gives you isn't a lot of help.
              95 Beretta Z-26
                MSD wiring diagram is perfect. I had no problems installing it. It is pretty straight forward.
                Just re check what you have done. You didn't ground the security wire did you?
                  no it's not the secuarty wire, that was one of the frist things i thought! does anyone know where any good diagrams are? the one that MSD gives you with the box sucks, and it's even more confusing with the adapter modules. Thanks for all your help guys!
                  3400 v6
                  TOG headers
                  RSM 62MM T-body
                  GRANATELLI MAF
                  Ported upper intake
                    if it helps any, the factory modual when your looking at it goes PNNPPN =362514. the panflet states that the red wire goes to switched 12v? thats what is confusing!
                    3400 v6
                    TOG headers
                    RSM 62MM T-body
                    GRANATELLI MAF
                    Ported upper intake
                      i got then backwards its PNNPPN = 253614.
                      3400 v6
                      TOG headers
                      RSM 62MM T-body
                      GRANATELLI MAF
                      Ported upper intake
                        You sure you got that wire in the right spot? If I remember right, the instructions also state something about some cars having a +5V wire that jumps to 12 after the car starts to crank. So you have to bump the starter or something to find that +12V wire.
                        97 Cavalier RS
                        3400, Isuzu MK7
                          How is the MSD instructions confusing? It is a perfect schematic and made complete sense to me.
                            The MSD wiring schematic is not so clear.
                            This is how to wire the Coils:
                            Colin
                              that's a grate schematic, thanks for the help. now to pull it off the car and check it. I see one thing wrong allready, the red wire!
                              3400 v6
                              TOG headers
                              RSM 62MM T-body
                              GRANATELLI MAF
                              Ported upper intake
