3500 with stock PCM and no ext trigger.
  • 3500 with stock PCM and no ext trigger.
    anyone interested in being a guinea pig? I have ideas that might allow us to run a 3500, with it's coilpack, no ICM, no external crank trigger, and DBC throttle, all using a stock format PCM.
    Possibly in a few months once I get my hands on another 3500...
    14.96@91.47 in the 1/4
    9.63@74.36 in the 1/8th
      do you have a DHP powertunr that you can flash a bin with?
        Drive By Cable. I didn't know what DBC was at first. So this is for a 3400 computer, not the stock 3500 computer.
          potentially, yes, it now comes down to the cam and crank position sensors. it might work, but I'm not 100% sure yet.
            Do you have a jimstim and the jimstimx? If the beta allows the LS trigger to be selected with a V6, I can see what happens that way before putting it on an engine/test stand. Gotta get the test stand setup still, so we will see which happens first:P
              I had a Jimstim, not sure where it is now! I've been thinking about getting another one and a JimstimX for this very reason.
