La1 and boost
  • La1 and boost
    So, the la1 swap miata project is getting going. Started stitch welding the chassis today.
    anyway, while the 3400 is on the stand, i can't help but wonder how 10psi would work.
    what turbo would be reccomended?
    would 3500 heads and intake be wirth the time and hassle, or would porting the 3400 parts be good enough?
    goals are for 300/300 at the wheels. May be a bit optimistic, but im willing to try.
    10 lbs of boost will make 300 up on a stock 3400. You can keep the longblock untouched
      What size turbo? Im thinking td04e, or hx35. Nit sure.
      i do have a 3500 upper and lower intake, as well as 07 inpala 3500 exhaust manifolds to play with.
        Go with a 58 to 62 mm compressor
