Anywhere to buy flywheel blanks ?
  • Anywhere to buy flywheel blanks ?
    Im attempting to adapt a t5 with a 60 degree v6 bellhousing to anther motor and was curious as to if there is anywhere to buy flywheel blanks that have not been drilled so i can get my crank spacing drilled ?
    If not I guess I can have one filed and drilled.
    It would probably be easier to drill the flywheel that fits the engine for a new clutch pattern. This is exactly what I did when I adapted a Nissan FS5R30A to my LX9. I used an F-body flywheel (for the thickness) and had it re-drilled for the 240mm Nissan clutch pattern.
      oops, clicked on the wrong thread.
