3900 Max timing degrees
  • 3900 Max timing degrees
    Does anyone know roughly what the stock 3900 runs for Max timing at WOT. Just want to get a baseline. Should it be in the 30degrees of timing or is that too much ?
    Also the cam is advanced 15 degrees correct ? Should it be brought back to 0 for optimal top end? Seems as if it is not very quick right now.
    Thanks and let me know
    Usually advanced cam would be for low end power, retarded for top end. And I typically run 20* of timing on my 3500 at WOT, down to 12* under boost.
    '86 Fiero, 3500, 4-speed
