3400/3500 hybrid turbo.
  • 3400/3500 hybrid turbo.
    I had a few questions for anyone boosted. I'll be doing exactly what the title says. What I'm wondering first of all is if anyone knows a cheap set of manifolds for sale or if anyone has some!? And secondly what injectors should I use? Again looking for a stock cheaper option.
    You might be able to use the stock TGP manifolds for your goals. Depending on hp/tq, 22lb to 42lb injectors are typically used.
    If interested, I may have a set of TGP front and rear manifolds for sale. PM me.
      22 lb is smaller than stock 3500 injectors so not nearly large enough. 36 lb from a 3800sc or 42 lb should be ok for low-med amounts of boost.
      '86 Fiero, 3500, 4-speed
        Sweet and those injectors from the 3800 fit the 3400 rail?
