3400 top end swap
  • 3400 top end swap
    After reading several threads about 3400 swaps and whatnot I have a question.
    Is there a significance in the 3400 block and lower end that makes it better than the 3100 that is already in my car. Or will the top end swap net just as much gain as swapping the whole motor.
    Sent from my iPhone using Tapatalk
    Blocks are fairly equal... benefit of a full 3400 is typically a newer engine overall and less mileage... More revisions were also done bearing and seal wise to the newest 3400's so if your doing a complete swap you end up with a slightly better setup regarding those items. As far as the top end only yeah you will net close to the same HP gain's but then again it's all dependent on the tuning you do to compliment the top swap.
    Also depending on year I think all small port 3100's did not have piston skirt coating on cylinders 5 and 6 but that's not a big deal, OR a deal breaker by any means... just another one of those small changes you see.
      Your 2003 3100 will see no benefit from a 3400 top swap... for all intents and purposes the only difference between your engine and a 3400 is the bore measurement. You cannot do the 3500 top swap because the 3500 heads won't work with the 3100 bore (too small). The only part you could do for an upgrade would be the 3500 upper manifold, but then you have to monkey around with mods for the throttle body, fuel rail, etc...
      3500 Plenum
      - Ben
        Didn't know he had an 03 3100... That would have greatly changed my answer... LOL
          Are you planning to build a motor?
          If so,i've got a complete low mileage 3500 disassembled in a crate. From lower intake to oil pan,though heads are bare (no valves/springs).
          I just threw the block in back of truck today with some other stuff for scrap so if you're interested let me know.
          It is a non VVT LX9 out of a Pontiac montana,was gonna build for a fiero but have a couple complete L67's so going that way with them.
            So basically it's full 3400/3500 swap or pointless?
            Eddie there is a full 3500 on CL for $550 unless that was yours.
            Think I'm just gonna live with the 3100 for now unless I stumble across a full 3400.
              I actually just found a 3400 from a 2000 grand am. Same price as the 3100 I was going to buy. Thinking I'm gonna go that route. Now just gotta research that swap.
                2000+ 3100 uses the same top end as the 3400 (basically depending on the source there could be some insignificant differences between 3100 and 3400 of the same year). So in a case like this swapping the top end between a 200+ 3100 and 3400 will net a zero gain, stock for stock.
                In a case like this I'm not even sure a 3400 swap would net any noticeable gains in power. Don't get me wrong, there would be an improvement, but not a huge one.
                  Damn this car. Lol.
                  So......... Cam, p&p, intake, exhaust.
                  Does anyone know if the 3500 exhaust manifolds will bolt to the 3100?
                    Yes they do... the question is does the front manifold clear everything and do you have enough room to route the exhaust pipe...
                    - Ben
                      My thoughts exactly. I was thinking about getting the OBX headers for the 3500 and doing whatever needed to make them fit. But I don't TIG weld yet and I have a hat time with the idea of hacking up $400
                        Other than doing the f23 swap I'm really getting discouraged about doing anything performance wise. No emissions around here. Prolly just get a cam and do intake and exhaust. Maybe port and polish a set of factory manifolds just for practice doing it.
                          Try hacking up $550 worth of header back in 2006 to just get SOMETHING to fit my Beretta...
                          Pretty...
                          CHOP CHOP!
                          Essentially what I had to accomplish from N-body headers to what I need.
                          After many years of abuse they finally got the treatment they deserved...
                          Real Ceramic Coating.
                          Also no one said a 3500 swap is pointless.... It may take a bit more work on your setup, like external crank trigger and designing a rear trans bracket or tail shaft bracket since you are planning a F23 swap... but in the end the 3500 will perform better. Also a 3400 with a 3500 top end will perform better than a stock 3100 would.
                          You just need to decide what you want to do, but a 3400 for a large port 3100 is almost an equal swap and would retain all the same external/internal sensors.
                          I have emissions in CT and listen to my lope video... That car still gets through emissions fine because it's OBDII... so think of what you could do with NO emissions... and it's actually EASIER for me to pass since I can disable everything in the ECU to display it all as systems ready and they don't sniff the exhaust. I would probably need two cat's to pass if they did that, Of course I would make them removable for a single cat when I actually use the car
                            I'm not gonna mess with a 3500 swap. Just gonna port and polish everything. Cam it. Do intake and exhaust and get it tuned.
                            All that with the f23 should make for a fun to drive DD/kid hauler/grocery getter
