DRTC
  • DRTC
    anyone have detailed instructions on installing the TCE DRTC? I know about the crank machine work, but that's all the info I have... main thing I need to know is how to use the two depth gauges that came with the timing set.
    I am interested also
    Mine should be back from cryo this week
      I was a bit curious to what the other pieces were that came with it. Depth gauge sounds good. I forgot that I have to machine the crank.. Guess I won't just be pulling off the cover and swapping over to the DRTC :P.
        You have to turn down the snout on the crankshaft, and do some slight clearancing on the block behind the timing cover. I think you also have to ground down one of the oil galley plugs.
        Sent from my iPhone using Tapatalk
        Matt
          I forgot that you also have to do some slight clearancing on the backside of the timing cover itself.
          Matt
            3x00 modified has installed one of these in friends car have to ask him what needs to be done
              One is supposed to be a depth gauge and the other is a straight edge that should lay flush against that and the gasket face of the timing cover when you mill out the inside of the cover... I think... I have to have them in my hand again to verify that, I'll check when I get home.
              You can see where I clearanced this cover...
              And the crank mod, Compare to yours to see the difference.
                install instructions attached as a PDF
                  That's what it was!
                  I didn't think it made sense in my head for one to be a straight edge for the timing cover... lol
