starting new build in a month looking for specs
  • starting new build in a month looking for specs
    hey all new to 60v6 have an 02 impala and the ability to cnc my heads any way id like, so my question is what specs/supporting mods should i get i have headers and am also porting upper and lowwer intakes, and want to do a cam re grind and add springs and new valves after my valve job is finished and i ultimatly plan on turboing this same setup so ya would be great if i can get some specs oppinions and suggestions on how to go about it so it can be n/a for about 6 months then go boosted 12-15 psi...thanks for any help yall can hand out
    Comp Cams makes cams(roller) for the 60 and they are not hollow like stock.
    Grand Prix trans with 3.33FDR
      Oh for real..giving me full authority over lift and duration of lobes, that's what I need a solid cam I can get ground for perfection lol
        Keep the stock cam for 6 months and the swap it when you add the turbo. Turbo cams and N/A cams are not really cross compatible unless your willing to compromise a lot. A supercharged cam and N/A cam are much more similar in design. After you have the rest or your parts and design laid out then figure out your cam. Comp will give you free advice and grind you a cam at no extra charge compared to a shelf grind.
          Oh we'll that's good to know all I have ever built are rx7s and turbo diesels..but I figured its time to put a lil more limp in the imps walk, so as far as head work I'm just cleaning everything up I have headers so porting to gasket match exaust as well as intakes, may get valve job down the line when I boost and put the new cam in so I was wondering should I leave some grit to the exaust and so on for maximum flow and wait till the turbo to smooth em all out( as I know boost loves a nice slick passage lol or should I go all smooth and purdy even w n/a in prep for that sweet boostage
            I always read not to gasket match the exhaust on the head. I always read you can open it up a little but gasket matching will hurt unless that is just for n/a
              I thought that the larger exaust as long as it doesn't leak and matches the intake is a good thing for a boosted engine? Are you saying that because if leaking past the header gasket?
                You can always polish the exhaust to a mirror finish. It will help keep the heat in the exhaust stream and prevent carbon buildup on the port walls. Depending on the gasket you may be able to open it up just a small amount but don't even think about opening up to the header tube size. You want a step from the port to the header and you also need to leave the walls of the exhaust thick enough to take the heat.
                  Oh I wouldn't take it out to tube size per say..idk how to put it, I want to keep the size the exhaust has but port a small amount of material, and then just open up the exaust shape some more instead of the stock outlet shape, so where should I polish inside to a mirror finish? Keeping in Mind if it doesn't get the best power n/a long as it can still get up n go but the best areas to polish for das boost
                    If there is liquid fuel present in the area then leave it rough. Everywhere else can be polished if you want. You don't want to change the port shape on those heads though. Keep it all the same and just clean up any obvious casting flaws.
                      Oh awesome that makes sence thanks bro, so what would you recomend for springs and valves, also any larger tb that I could find at a pull yard that would mount w or without a adapter?
                        I'm not aware of a bolt on option for the TB, I'm using Manley valves and PAC springs from WOT tech in my turbo build.
