Is this normal?
  • Is this normal?
    Is it normal for an early Gen 3 3100 to sorta fall on its face under harder acceleration?
    I've noticed that the engine seems to produce less power if I try and push it hard, and I want to make sure that's not a bad sign.
    Did you change the fuel filter yet?
    Mine did seemed to fall on it's face in the top end do to the small port intakes. The 3400 intakes helped that.
    Grand Prix trans with 3.33FDR
      I haven't...but I think it's just because of the small intake ports. I'm sure if I swap to 3400 intakes I'll get a better power band.
        It's a good idea to change that filter if you have not done that yet.
        I did see a little loss in the low end power with those intakes. But I bet you already know about that.
          Well the low end doesn't matter much to me, I'm not pulling trailers with a Buick Skylark or anything else that would require more low-end than high-end.
            Yeah I came from V8's and had a 3.1, so low end power is something I love. But good point.
              Believe me, I wish I was driving a 2nd gen Trans Am around. But I gotta make do with what I've got.
                Oh yeah I know how that is. I bought a Cavy with an Ecotec and I'm not happy, but when I buy a car I'm stuck with it.
                  it's all relative.
                  when does the engine seem to quit pulling? around 5000RPM?
                    it's all relative.
                    Yeah, around there. It just runs out of breath.
                      with a small-port 3100 and no significant changes to it, that's about right. should pick up around 3000 and pull to around 5000. by 6000 it's really out of it.
                        Okay, good. That's what I wanted to know.
                        It's always important to know what's a problem and what's just a design flaw.
