On going 3.4 / 3400 turbo build
  • On going 3.4 / 3400 turbo build
    As I stated in past post I have started gathering parts for a turbo project using an S10 blazer as a platform[now has a sbc v8].I have a 3.4 rwd block,3400 upper,60-1 garrett turbo, LX5 65mm TB and mega squirt.I plan to use the stock cam with stronger springs.Not new to building engines but no practical experience with turbos,I have done extensive reading on the subject and can plot a turbo map.I think 15 lbs. would be a practrical maximum limit for a 3.4 rwd blk using hypereutectic pistons.I check the store for the TB adapter but it says "out of stock" are they still available ? Any input or suggestion on my project will be appreciated .OOPS,should have put this in Boosted,sorry !
    You will be fine with stock pistons and 1bar, just don't detonate.
    The TB adapters were put in line at the water jet, will have more soon.
