I am looking to get the under drive Pulley from MRZ but am curious on how to transfer the Crank Reluctor ring from the factory crank pulley to to MRZ crank pulley. by the way this is for a 2000 3400 motor
MRZ underdrive Pulley?
Money spent better somewhere else. Search why
Sent from my iPhone using my iPhone at work cuz I have nothing to do
Originally posted by betterthanyou View PostAgreed. An engine without a damper is one that will live a shortened life.
Discuss amongst yourselves.Matt
Discussion over discussed. Soon these threads will just be locked and forgoten about.
WE'VE CONVERTED SOMEONE!!!!!!!
HAIL TO THE 60DEG GODS!!!
Originally posted by mfuller View PostWhile I am inclined to agree, does a dual-mass flywheel (a-la a 3900/F40 combo) accomplish the same thing? Does the presence of a DMF negate the need for a damper in the crank pulley?
If you want the benefits of an under drive pulley and none of the risks of not having a damper then make all the other pulleys bigger. All the GM cars and truck use the same width of belt so finding and adapting parts may not be too hard. This also allows you to customize the drives. So if you need that alternator to give full charge at idle then you can continue to have that but change the water pump and power steering pump pulleys to under drive them and save on power only in that area.Last edited by geoffinbc; 01-21-2012, 02:00 PM.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
