putting 3500 upper parts on 3400 block??? ASAP
  • putting 3500 upper parts on 3400 block??? ASAP
    ok so when i put 3500 heads, lim and uim on a 3400 la1 block
    do i use 3500 head gaskets or 3400 head gaskets?
    and what else exactly do i need?
    3400 gaskets and its pretty direct swap other then a temp sensor too if im not mistaken it been while since i did it
      the injectors and 3400 fuel rail fit in the 3500 lim ?
      and do i use 3400 or 3500 lim gaskets?
        Yes they do Slinky
            3500. but dont forget, the 3500 heads and lim HAVE to go together
              and i use 3500 lifters and pushrods im guessing?
                those are the same as the 3400
                  ok ill just use the 3400 ones i have, thanx!
