DIS external crank trigger kit for Fiero?
  • DIS external crank trigger kit for Fiero?
    Hey all,
    I'm converting my '87 Fiero GT with the "stock" 2.8 to DIS with the 7730. My problem is getting a bracket made for holding the crank trigger. The WOT-tech crank trigger kit won't work with the Fiero 2.8 because it's setup more like a RWD pulley system from what I understand.
    Does anyone else out there (or would be willing to that has done it before) make a bracket or a full kit with relector wheel?
    Thanks,
    -Ryan
    We have a new kit that has a notched RWD dampener and a CPS mount that was designed to use a RWD timing cover on a LX9. Not sure if it will bolt to a 2.8L or not. There's a 2.8L at the shop and I will see if the bracket will fit.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
      :thumbsup: Very much appreciated if you could!
        You can probably steal the DIS trigger bits (and maybe front timing cover) off a 3.4 Camaro.
