3500 sensor question
  • 3500 sensor question
    just above the crank sensor on my 3500, there's a sensor or device of some kind, it's rather large and has 3 larger wires going to it.
    what is it? anyone know?
    I think you will find you have one on each side. I think its a knock sensor.
    Roy
      no, this device is only on the back of the motor (right side)
        Mine had one on each side of the motor. I am still going with knock sensor. Mine went in the trash, whatever they are I didnt need them.
        Roy
          if this is a knock sensor, it's the biggest one I've ever seen...
            Does it look like this?
              Is it round with a 15mm bolt going through the middle of it?
                nope, already said, not a knock sensor.
                  here's a pic...
                    Hmmm. My 3500 has a plug in that hole. And my right knock sensor was in the hole just above and to the left of it. It looks like a water temp sender to me. Hopefully somebody can identify it for sure.
                      Never seen one in an LX9 but wouldn't be surprised if it's a block heater.
                      MinusOne - 3100 - 4T60E
                      '79 MGB - LZ9 - T5
                      http://www.tcemotorsports.com
                        There is a big plug right there in my LNJ Block
                          Thats exactly what it is. The engine probably came from a van.
                          http://www.compnine.com/modimg.php?i...16TU01-005.gif
                            it's an Engine block heater!( car was from Minnesota!)
                            boomofdoom88, that site is very helpful! thanks for sharing!
