Starting my engine build.
  • #16
    I don't know if I would trust .030 on a motor that will make power to 6k and beyond. Maybe a stock Gen 1 or 2 setup that doesn't do much past 4500 RPM, but gen 3 top end = higher RPM = more rod stretch.
    Well if you can get away with .040" quench on a 4"~4.3" piston then .030" quench on a 3.7" piston is not unreasonable. The reason you need a safety margin is for a bit of rod stretch and the piston rocking in the bore. And the smaller a piston is the less these variables will be a problem.
    • #17
      That's a nice looking 'bird, good luck with the build
      • #18
        Thanks!
        I haven't purchased any parts yet, Im saving paychecks so I can buy everything in the bottom end at once.
        1988 Firebird
        3.4 60*V6
        9 Bolt Rear, 3.27:1, Disk brakes
        Edelbrock 3790 Cam & Lifters
        COMP Cams Magnum Steel Roller Tip Rocker Arms 1414-12
        COMP Cams High Energy Pushrods 7816-12
        COMP Cams Valve Springs 980-12
        PaceSetter Headers 70-1206
        • #19
          What fuel are you planning to run with 11.5+ compression?
