Originally posted by ericjon262
View Post
I took these pix from the store, so the credit goes to Ben.
Judging by the oil hole positions in the underside of the piston, there isnt much space to move the rings up that far, even with custom pistons. Maybe a 1/4 inch tops.
Triple edit:
Basing myself off wanting a 1.75 R/S ratio with a 6" rod, I would end up with a 3.43" stroke, .12" over stock.
This would net me 3624CC based on an otherwise stock 3500.
So that puts the piston pin at +.42" at TDC over stock, and at .52 using an SBC piston pin.
These little engines are a squeeze...
What do you guys think an acceptable R/S ratio is?
