Torque Output 2.8 HO (LH7) 1981 vs later years
  • Torque Output 2.8 HO (LH7) 1981 vs later years
    I've read the 1981 version of this engine had highest torque with 165 ft-lbs vs 145 ft-lbs "due to emissions regs". Does anyone know what accounts for the higher torque in 1981 version? No Air Pump?
    The cam and compression was better. The heads were the same as all fuel injected iron head motors. If you were to purchase a modern cam today it would outperform that old HO cam. AIR pumps do not rob any measurable power.
      How much of a bump in HP do think this motor could get with a modern street cam like a Comp Cam 240H that would be tuned to run with everything stock in the motor and w/ ECM? Do you know where I can find the OEM cam specs for the motor? Looks to me like the motor might have to be jacked up to clear the strut tower to remove the cam.
        I ran a 260 in a 2.8 with stock computer[87 s10]with no problems,less than a 260 waste of time in my opinion.
          Yea I would not run a 240 cam in a street car. Maybe a 4X4. I am running the 252 cam and it is a great cam for daily driving, towing and powering up mountain hills. But if I had a small car I would go for the 260 cam too.
          The HO cam specs are in the Chevy Power Manual.
