Camshaft Options...and yes i searched
  • Camshaft Options...and yes i searched
    ...and came up with 12 pages of results that pointed me to the Crane Cam H-260-2 which, as i understand correctly, can no longer be bought. Here is my situation...89 2.8 Beretta gave up the ghost coming back BFest in Chicago. I am still tossing around options to replace it; even entertained a 3500 swap. But just this last weekend at the yard here in Vegas, i stumbled upon a 25k mile 3.1. I am now leaning against the 3x00 swap trend and keeping the generation 'correct' engine in it but want something better than stock that is still streetable and something that will still give the fuel economy i am used to during long (BFest) trips. I am not considering any power adders and would like to stay around the H-260-2 specs. I know WOT-Tech sells the cams, but would like other options.
    Thanks in advance!!!
    Ron
    Las Vegas, NV
    1989 Beretta GT
    Comp also makes a 260 grind. But, looking on Summit...
    Crane H-260-2 : http://www.summitracing.com/parts/CRN-253901/
    Comp 260 grind : http://www.summitracing.com/parts/CCA-16-233-4/
      The Comp grind is not comperable to the Crane.
      Have Ben or I design you a cam.
        The COMP grind is a good cam. It is streetable too. You could go custom depending if your on a tight budget or not.
