3100 Malibu heads milling recommended
  • 3100 Malibu heads milling recommended
    Hi guys, I want to know what is the best milling heads for my Malibu 00 3100 engine? I saw on all sites that the maximum is .020 but I want to know if .040 is better? Anybody milling to .040?
    It is never "better" to mill the heads. Don't touch them if you don't need to. There is only 2 reasons to mill a head. 1. Its not perfectly flat and needs to be corrected for a rebuild. 2. You want a slight compression increase.
    If you after the second scenario then mill the heads and block 0.010/0.010 don't take 0.020 out of the head.
      and number 2 is quite useless you MIGHT get 5 HP from it. less likely since you might only get back the HP you lost from an engine this old. Instead 3500.
      Mike 60degree addict.
        Ok, I want to get compression. I want to combine it with a racing cam. That's the reason why I want to milling.
          Milling the heads and a high-lift racing cam will result in bent valves, or at a minimum, the valves making their own releifs into the pistons. There really isn't a whole lot of room to play with inside the chamber. And if you don't believe me, ask Superdave, as he knows from experience (and I don't think his heads were even milled).
            put in a set of pistons for a 3.1 Camaro if you want higher compression (about 12:1), milling the heads is a waste of time. Your other option is to have the pistons shaved .020" then run camaro 3.1 headgaskets, that'll get you up to around 10:1
            Yes, i have dents in my pistons. That's my cam's fault though. lol
              You have to be careful with block milling, as the piston will then be closer to the head and your head gasket needs to be thick enough for clearance.
                My last 2 sets of 3400 heads have been milled .020".
                Like you, I was looking for the (slight) compression increase.
                Knowing what I know now, you should only mill the heads enough to get a flat surface.
                Matt
                  Little late to join the party here, but what amount would have to be milled off a 3500 head to get the CR back up to 9.5 or 9.8:1 when used on a 3400 block?
                  Not my question but one someone asked me.
                  I though it would be too much to bother with... He plans to still use all stock parts everywhere else, he just wants the increased flow of the 3500 heads.
