3.4 dynoed
  • 3.4 dynoed
    dont forget about the slipping clutch , it started to slip around 1-2 psi but heres some numbers anyays
    174.6rwhp and 210rwtq @ 4332 rpms(which is when the clutch slipped)\hp and tq was only at 35% throttle and about 1 psi of boost not even
    picture below shows were he got out of it
    get a few issues cleared up and u should b looking at around 290ish rwhp and 350rwtq @ 5 psi if not better that car is going to be a beast once the boost gets turned up
    he car is overly rich and throwing a false lean condition i gota go threw the logs better but they show a 18ms pulse width on 48 pound injectors which shouldnt be so its way rich.
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
