Edelbrock Intake Bolts
  • Edelbrock Intake Bolts
    Anyone know the sizes and lenghts of bolts needed for the Edlebrock 3785 base and 3789 four barrel upper when bolted to a 3.4? Appears to be two different lenghts. Quantities and sizes required? Is there a GM part number for the whole set? Do they have the flanged heads? Thanks
    Most likely the same as stock. What happened to your old bolts?
      I bought a 3.4 crate engine long block so I am missing a lot of bolts. Unfortunatly I have not found a good source of information about bolt sizes so every thing needed has to be measured or the info from someone with more experienc ethen myself.
        Well it would be easy to get the bolts from your local GM dealer. Use bolts from an S-10 with a 2.8L. There are 6 studs and 4 bolts. Or you could get all the stuff from a junkyard.
