3100 with 150,00 miles low performance
  • 3100 with 150,00 miles low performance
    runs well but doesn't have the power and acceleration that it did just 15,000 miles earlier. any ideas or recommendations what can be done?
    2001 Chevy Impala (3400)
    clean the MAF, new spark plugs and maybe wires, change fuel filter, clean air intake filter and box, run some injector/fuel system cleaner through it.
    that's all the easy maintenance things i could think of off the top of my head.
      This is a good list of things to check: http://www.2carpros.com/first_things..._low_power.htm
      How old is the O2 sensor? Finding someone with an OBD2 scanner can show if the other sensors are giving proper readings too. If previous suggestions fail to give results then the issue is likely internal wear like piston rings or a stretched timing chain.
      1995 Grand Am SE
