Hi everyone a couple years ago I was building a fiero up but then I moved away for a while to go to school and it sat in storage but now I'm back and looking at it. It's gonna take a lot of work but I think its got potential...
Here is what the car had on it when I acquired it: 1987 Pontiac Fiero GT with 2.8l motor and getrag 5-spd transmission, lowering springs/shocks (don't know what kind but it beats you up), ACT clutch (I want to say stage 3 but dunno it's excessively grabby more so than ACT stage 2 in my Miata), front tire 225mm low profile on 16" rim, back tire something like 275mm? on 17" rim, bigger radiator, blown motor (blew 3rd time I drove it first time was 6hr drive home from buying), it is painted all black and quarter panels are tinted, motor had full headers + exhaust (irrelevant, but it was true duals with each bank of cylinders getting their own header and full exhaust in such a way that the 2 banks exhaust streams never met), cold air intake (cone filter and some tubing I guess that's an intake that's what dude called it I dunno it looked like he bought like a crx intake off ebay and hacked it up and kinda twisted it funny to make it fit then put a lot of silicon couplings and what appears to be expensive duct tape on it and it looked kinda dangerous and I'm surprised it made it 6 hrs home but that's for another story...sorry for all that...), lightweight neutral balanced flywheel (if I remember correct only the '88 fieros used neutral flywheels all others had a weight bulge on it which makes me think that this is not the original 2.8 correct me if I'm wrong), the original interior is out of the car but it is available as is new carpet from fiero store, I think the motor was internally stock but cant be sure haven't taken it apart I just know it's dead, upgrade brake pads and rotors (and maybe calipers as well not sure), poly bushings...I think that's it...
sorry I know that's a bit much please keep reading I'll try to do better...
I saw this fiero with a blown motor as the perfect platform for an engine swap. I went to the junkyard and wound up getting a 3400 from a 2000 grand am. The motor was then rebuilt and slightly modified before it was installed in the car.
The motor has: pnp heads (the heads were "cleaned up" by the shop and the combustion chambers were polished), mildly reground camshaft (sorry I lost the cam card I posted it on this site back in the day dunno if it's still up), LS6 valve springs (with the proper supporting mods like valve seals and seats), 3500 upper intake manifold, all manifolds have been "port matched," pistons are thermal coated (sounded cool and shop threw it in with the heads), better than stock head gasket (no idea beyond that), new bearings and bolts, everything got checked out, I think it has a higher pressure oil pump or something, uses the light neutral flywheel of the 2.8, 36 lb/hr fuel injectors from grand prix 3800 supercharged (cleaned and flowed), I think that's about it. Pretty much all else is stock.
Things I need: throttle body (I have one from a 4.6 mustang but the linkage is all backwards and I can't figure it out really but it does bolt to the manifold and looks ok with ford logo ground off
), prolly gonna need an intake tract other than the crx thing, need an exhaust system from exhaust manifold-back.
What I have: access to a MIG welder (I don't know how to weld but I'm a fast learner), a garret T04B turbo (can't remember details I think a 57 trim compressor though), 3 intercoolers (4th gen supra, dsm, and mitsu starion), water injection kit (a decent one not a windshield squirter nozzle), blow off valve (hks super sequential, can vent to atomosphere or recirculate), a PCM from something (an early '90 grand prix I think can't recall specifically, I know it's capable of using code from the turbo grand prix and running a 2 bar map sensor thus being able to tune for boost), the items necessary to interface with said pcm using a laptop and programming it (I think I have a program called "GMPCM" has anyone heard of it?), electronic boost controller, skills at automotive electrical work, experience with boosted cars and ecu programing (turbocharged volvo 850, miata with m45 supercharger and standalone ecu), car-working-on ability (see miata), some other stuff I'm sure.
My goal is to basically put that stuff on that car and make it drivable. I'm not sure quite how to get there, so I'm going to ask a few questions:
What is the best way to physically attach my T4 turbo to the engine? Can I do it easily using the stock exhaust manifold? How? Would it be better to figure out some other manifold solution?
What should I do with the exhaust after the turbo? Wrap it around the engine? Snake it straight down and out the back? Use a 1 inlet, 2 outlet muffler or a y pipe or something else?
What should I do for engine management? Is using that PCM feasible? Will that program work? Should I use something else like mega-squirt?
Should I bother with an intercooler if using water injection? How do you put an intercooler on a fiero anyway?
Where would I get oil for a turbo? Best place to return oil?
What should I do for a throttle body? Is the mustang unit feasible or do I need to get something else? What else is there?
Imagine you were in this situation, what would you do?
