Head swap, yes or no?
  • #16
    Hey, Brian, do you post over at the PlanetIsuzoo forums? When you get this swap worked out it would make a great article for the site. I expect there's quite a few Isuzu Nuts who would be interested in this!
    BTW the O.P. (michael) with plans to offer a TBI-to-Multiport adapter harness might have another market with the ZuZu folks since the 3.4 TBI swap is a popular conversion.
    The ability to upgrade to aluminum heads and improved EFI system with better economy, driveability, and more HP potential than a TBI would be great. I may have to build another motor for my Troop when I retire next year! I have a core 3.4 hanging around in the garage just waiting for a project!!
    Thanks for the Very Informative Thread.............ed
    p.s. I bet that Lil' Red P'up moves out quite Smartly with a 3.4 in it! Quite a bit lighter than a Trooper.
    '90 Trooper 3.4 Conversion, bored intake, Holley Big-Bore, 1.6:1 Small Block Chev V8 roller-tipped rocker arms.
    • #17
      Hi, Ed,
      I have been to Planet Isuzoo to see if anyone had done any conversions other than the GMPP 3.4 upgrade. None that I saw.
      Where I am now is a full 'transplant', per Dave, for an '04 Malibu 3500. Sounds reasonable/doable. I hope to document all as I go, for those who would be interested. Keep in touch! Nobody needs to 'reinvent the wheel' is why I came to this websight to start with. Super folks, great help. Much credit to Brad.
      Brian
      • #18
        Well the good news is you wont have to move the starter.
        • #19
          Originally posted by lilredtruck View Post
          Hi, Ed,
          Brian
          The mechanical side of it will be easy, it's the computer side that's going to take some effort. It's definitely do-able though.
          I think once it's all said and done you'll really enjoy the power increase and the better gas mileage.
          • #20
            Hi, Ed,
            Page 2!
            You might be interested in knowing that I bought my '92 P'up new, it was built in June of '92 in Indiana. I have put 684K miles on the chassis. I replaced the 3.1 with the 3.4 at 303K; thought I had a cracked head/block due to massive water loss w/ no visible leaks. LSS, it was the intake manifold - cracks between water jacket and 1-2 intake passage and thru the bottom into the valley as well. I'm on my 3rd manifold now. For those who are having a similar problem, cut off the lower spring and seal from your radiator cap and run unpressurized. Reduces the problem. I add about a pint of coolant every 800 or so miles.
            Brian
            • #21
              Hi, All,
              New thread - "3500 into a P'up".
              A few questions there.
              Brian
              • #22
                OK, have the 3500 from the '04 Malibu. On E-bay is an engine harness for 92-93 Cavalier/Beretta/Corsica $75.00. What do you think? I went to a Pull-A-Part yard today, got the fuel rail and started on getting the harness. 2 hours later, very little accomplished. Your thoughts, please.
