RWD 3.1 crank in RWD 3.4?
  • RWD 3.1 crank in RWD 3.4?
    At school I've been tearing apart a 3.4L out of a 95 Camaro and on the crank it says 3.1L. Is this normal?
    1988 Firebird
    3.4 60*V6
    9 Bolt Rear, 3.27:1, Disk brakes
    Edelbrock 3790 Cam & Lifters
    COMP Cams Magnum Steel Roller Tip Rocker Arms 1414-12
    COMP Cams High Energy Pushrods 7816-12
    COMP Cams Valve Springs 980-12
    PaceSetter Headers 70-1206
    They are the same crank, so yes. Only difference between the 2 engines is the bore.
      Yea thats the way they are. I have never seen a crank that says 3.4. I am willing to bet every crank up to the 3500 says 3.1L except for the 2.8L of course.
