It has begun...
  • #16
    No, as stated, the oil pan will be what gets modified, therefore allowing the engine to come foward a couple of inches and let everything clear the firewall. Now its just down to how much to modify the oil pan...
    • #17
      Looks like a dry sump pan is in order.
      Your local OBDII moderator
      2000 Grand Am GT w/ WOT parts
      • #18
        how far back can you chop the pan before you start running into the windage tray and all that junk?
        looks like you need to do a Canton-style pan chop the front back, and add to the sides around the bottom. 7qt pan FTW!
        Cammed 3400 --> 224whp 210wtq
        Cammed 3500 --> ???
        1 of 5 3500 J-Bodies
        • #19
          Originally posted by Charless1 View Post
          Goodwill Donation Box FTW!!!!!!!!!!!!!!
          Lol, just don't get caught, that's classified as theft (just like when I went diving at the local cardboard box recycling bins for boxes to use for moving).
          Will a RWD pan fit a 3x00? Or how about a DOHC pan?
          • #20
            no, because the 3x00 pans are structural aluminum, with the crossbolts that go into the main caps. gen1 and Gen2 pans are just steel, bolt on oil pans.
            Cammed 3500 --> ???
            • #21
              As long as I keep the notch level with the existing notch in the pan, there won't be any interference with the windage tray. Now the pickup tube might be a possibility, but I think we can get it without any issues. We'll see.
              • #22
                Yeah, that crossed my mind while taking a leak this morning when I got up, lol. That wouldn't be a wise move to go with with the power output that is being hoped for with this thing. 2 bolt mains and no crossbolts FTL.
                • #23
                  This thread is full of win!
                  BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
                  • #24
                    man this car is so clean, i cant get over it.
                    • #25
                      Oil pan operation time...
                      And in case you were wondering how thick the 3x00 oil pan really is...
                      Rest of the week is pretty booked up already, so not sure when I will be able to bolt this up to the engine and check clearances.
                      • #26
                        I can not make that out, how thick is that?
                        • #27
                          i want to say 1.23cm, which is ~.48" if my math is decent...
                          • #28
                            looks like 6mm to me
                            99 Grand Am GT
                            1357 cam 227 233 .050 dur
                            515 515 lift 112 lsa
                            • #29
                              metric system .................................................. ......................... me
                              upon further inspection, i'll have to agree with you.
                              so roughly, .245"
                              • #30
                                Add a c hair on that, sa 1/4" and call it a day LOL
                                As of April 2
                                Engine: 2006 SV6 3500 LX9
                                Trans: 2002 Getrag F23 5speed
                                Injectors: #36 GTPs
                                TB: 65mm TCE
                                Maf: 1999 3400 Montana.
                                Beverages: Ice Cold CANADIAN.
