CR Question - 3400 w/3500 heads
  • #16
    So your saying not to polish the intake becuase it will decress the atomization of the fuel, and not to gasket match the exhaust so it has a vaccum effect when released, correct?
    • #17
      What about for a forced induction setup? I've cleaned up the ports on the exhaust side and took just a smidgen of material in select places. Should any effects (good or bad or null) be of noted?
      • #18
        The intake should never ever be polished because it doesn't improve flow and it creates a place for fuel to stick. You want the fuel to stay in the air. The fuel pressure/injector spray pattern are the majority of atomization though.
        Exhaust, its not about vacuum really. Anti reversion, and gasket matching is useless for flow.
