LIM flip for hybrid buildup...
  • LIM flip for hybrid buildup...
    Okay guys, as some of you may know, im going to be starting a 1g2.8/3400 hybrid build soon.
    Like this will be in a rwd nissan truck, I prefer to have the coolant line coming out at the front of the engine, for obvious reasons...
    I havent disassembled the 2.8 yet, as it is still my daily driver, but I just want to know if I can flip the LIM to have the coolant line at the front side of the engine.
    Thanx in advance for your help
    -Erick Garibay
    Originally posted by Mars
    Haha ^ Wrong Wheel Drive.
    No 60ºV6 at the moment
    Yes.
      WOoT!!!!
      Thanks Brad
        Yes, BUT, some years of the iron heads had a tab on the top of the timing cover. Just hack it off to clear the FWD coolant neck (gen2 FWD might be ok).You will see exactly what I mean when you try to bolt them together through
          @ forced: Did you run any issues running a g.3 top end?
          Seems like im doing something pretty similar to you except with a 2.8 and a 3400 top end.
          The only thing that worries me for now is the cooling system.
            I would be more worried about how you are going to get a crank reference signal for the DIS.
