94 Firebird 3.4L OBD1 swap
  • #16
    Ok will do. About the valvebody swap, that sounds like a good route to go and I have experience with valvebodies which means it would be an easy feat for me to accomplish, but I wouldnt want to dive into this without more information.
    94 Firebird 3.4 DD
    252000mi. All original
    • #17
      Hmm amperage eh? PWM can control amperage, but so can other ways... Someone with electronics knowledge could whip up something that reads a 2nd MAP and varies the current based on load... You could even put a potentiometer on there to chang the bias incase you wanted more firmer or softer pressures per load.. Wouldn't be that hard to do I would think... Unless the MAP is not really linear... But that could be overcome as well but would require a bit more knowledge of electronics. Maybe a PIC IC would be good here...
      • #18
        MAP is very linear.
        (.369*N)+10.354 = kPa
        that's the equation i use in all of my ADS, XDF and ADX.
        essentially, except for the 10.354 offset, it's perfectly linear.
        i had a chart somewhere that gave voltages vs kPa readings... oh well, takes two minutes to make.
        EDIT: for this situation, this should work:
        kPa____Voltage___A/D Counts
        15______.25__________13
        20______.51__________26
        25______.78__________40
        30______1.04_________53
        35______1.31_________67
        40______1.57_________80
        45______1.84_________94
        50______2.10_________107
        55______2.37_________121
        60______2.65_________135
        65______2.90_________148
        70______3.18_________162
        75______3.43_________175
        80______3.70_________189
        85______3.96_________202
        90______4.23_________216
        95______4.49_________229
        100_____4.76_________243
        • #19
          Hmm. I bet you could make a quick and dirty circuit with a voltage regulator running in current regulation mode, controlled by a 2nd MAP that was running off 5v (possibly from another voltage reg). If we knew how much current the force motor needs, that could be devised....
          • #20
            the highest you can read according to the datastream is 5 amps...
            56 CURRENT FORCE MOTOR COMMAND CURRENT
            AMPS = N/51
            57 CURRACT FORCE MOTOR ACTUAL CURRENT
            AMPS = N/51
