Mechanical Gauge installation
  • Mechanical Gauge installation
    I'm building a www.StalkerV6.com which, as you may know is powered by a 60 degree V-6.
    I've converted my 94 3.4 Camaro to a Holley 4 Barrell Carb intake and a conventional distributor.
    As I opted for mechanical gauges (Oil Pressure, Oil Temp and Water Temp) I'm at a loss to figure where to install the various sensing units.
    (BTW, I did find some kind of sender unit in the oil pan near the oil pump - Is that just a "No/Low oil sensor" ?
    TIA, Jim
    Be well,
    Jim Gunther
    "T" off the oil pressure sensor and install your gauge there. the oil pressure sensor is located around the Oil filter area. in some cases there is a oil plug in the adapters (if the Fbody used the filter adapter) that route the filter down instead of right out of the block.
    the pan unit is a Low oil sensor.
    Colin
