3100 compression
  • 3100 compression
    What should a good fresh 3100 have for cranking compression? Does GM have any specs for it?
    normal would be around 150psi
    the recommended minimum is 100psi, with no more than 30(?)% difference between the highest and lowest cylinder.
      Could a stock 3100 have 200psi?
        depending on how well the rings and valves are sealing and how much carbon has built up inside the chamber, yes.
          With 190,000km, mine was between 170 to 185 psi. Warmish and no oil added.
          1995 Grand Am SE
