Anyone have a list of performance parts vendors?
  • Anyone have a list of performance parts vendors?
    I have a 92 S10 with the 2.8 TBI engine and I don't want to swap an 8 in like everyone else I am trying to build the engine. I cannot for the life of me find any place that sells performance parts for this motor.
    Some help would be greatly appreciated.
    aftermarket parts are virtually non-existant for the 2.8.
    you either have to make do with what you have, WOT-Tech or swap to a more supported motor.
      he means you cant go get an edelbrock manifold and swap in on :P
      but you can get cams for them, prolly put 1.6 rollers on there with some work
      make-your-own-headers
      port it properly
      exhaust
      higher fdr? rear end dunno
      re-tune
      etc..
      got to put some elbow grease into it
        Well I found the 3.1 stroker kit and the cam and rr's but I couldn't find anything like heads or intake manifolds as you said.
        With the right porting done to the intake as well as the heads with the stroker kit , cam and rr's would I pass the 150hp mark?
          Should be able to do it.
          I've been playing with Desktop Dyno 2003 on a iron head 3.1. Using approximately stock head flow, a 2030 cam with 1.6 rockers and the stock 52mm throttle body, the program calculated the following power and torque:
Name:	stroked 2.8 guess.jpg
          Not much point in revving the engine past 5500 rpm but does show + 32 ft-lb peak torque and +20 HP peak power compared to the fuel injected 2.8.
            I just figured I would do something different then a V8 swap and since I have two 2.8 engines and two 5 speeds for those engines and an extra stock rear end, I might as well keep all the factory components, just build them up.
            I know people with machine shops, I know people who can weld up some headers so maybe I might just stick with the little 2.8.
              You can turn a 2.8L into a 3.1L very easily. All you need is the 3.1L Crank and Pistons. With a .040" Overbore you have yourself a 3.2L
              There is a ton of cams Available http://members.shaw.ca/betterthanyou...haft_guide.htm
              There is also a ton of rocker arm choices out there. I believe COMP has the best deal going with there Roller Tip Magnum rockers which are about $120 for the set.
              Since you have TBI the best option is a stock intake bored out to take a 4.3L throttle body. If you don't have the means to do this I can sell you one.
              Hedman and Edelbrock sell headers
              www.tbichips.com can burn you a chip after all your mods are done.
                Thanks betterthanyou! I appreciate the help, looks like I might have a tiny little 2.8 monster to play with soon!
                  If you want a monster then toss on a 3400 top end, headers, 260 cam and convert the thing over to DIS.. you could make 200 HP easy and great torque. It's a little more work though.
                    Well at first I might just build the 2.8 I have sitting around to be a bit more mild. Once that's in I have tons of time to have fun with the pepped up 2.8 and continue to build my other one to be even stronger.
                      despite what was previously said there are a crapload of performance parts for the iron head engines.. just don't expect a miracle when it comes to power.
                      Edelbrock sells 2 different intake manifolds: http://www.edelbrock.com/automotive_...ormer-v6.shtml
                      All the flat tappet cams that Betterthanyou posted, Headers, and there even was a roots blower kit for the S10/S15.
                        Yeah for TBI motors there are no intake manis thats what making me mad lol.
                          There is no point on wasting your money. The stock TBI manifold is fine. Just bore it out to fit a 4.3L throttle body and clean up some of the casting flash.
