A few years back I ran an 1970 Olds W-31 Cutlass. For those of you that don't know, they had larger valves, radical, balanced and blueprinted, forged internals, all factory. The stock pistons were 10.5:1 flats. We shaved the heads, IDK how much, but the engine shop came up with a figure of 13.7:1 compression on copper gaskets. The heads were shaved so far the stamping numbers on the bottom of the heads were flattened. We also had to have a good deal taken off the intake to get the ports and bolt holes to line up again.
My question is, and does anyone know.....
How much can you take off the 3500 heads and still be safe?
How much more compression can I get on stocker gaskets, with the .020" over bore diamond pistons with max shave on the heads?
How much valve clearance am I going to have with those 11.5 pistons?
1. Car is drag only and I don't expect engine temps above 150 degrees.
2. Yes I want 13:1+ compression. Don't ask it's an old school thing.
This is also pending Ben's finding's of flow on a race ported 3500 and his reading above .600" lift. Waiting patiently for his new flow bench!
