3500 UIM
  • 3500 UIM
    What can I do for the EGR in my 1996 beretta? do I have to buy the adaptor plate or can I hook up the 3500 EGR?
    Mike 60degree addict.
    nobody knows???
      Hook up the 3500 EGR. you'll need the EGR tube that goes to the exhaust manifold as well.
      Easy as can be.
        i dont think the 3500 egr will run properly bein that its from a newer car and shouldnt really interchange parts when it comes to things like that.
        i would reccomend buyin the adaptor and usin your stock egr
          Uhm,
          1) There is no adapter to adapt a 96 EGR to a 2000+ EGR as they are the same thing just mount differently. They are both OBDII EGRs.
          2) They have the exact same internals and electrical insides/connections.
          It's no different than swapping exhaust tips... they may look a little different, but function the exact same
          Or here is a better example, swapping MAP sensors... I swapped to the 3500 MAP sensor, different connector, but gives the exact same reading as the old OBD1 sensors.
